FREEDOM83 H10 Optic
FREEDOM83
Gegeven waarderingen: 304 keren
Ontvangen waarderingen: 290 keren
FREEDOM83 H10 Optic
Bericht door FREEDOM83 » 27 dec 2024 11:03
New project start
more arrived parts , happy weekend !!
That for the moment , and waiting for :
Cesco (17 feb 2025 22:50)
FREEDOM83
Re: FREEDOM83 H10 Optic
Bericht door FREEDOM83 » 30 dec 2024 09:52
A productive morning, tranny mounted with the overdrive and a screw to simulate the gear shift lever :
Then the links, I I have made a support with an old joint so that I can screw the ball joints in faster and without suffering hahaha and everything is placed in the support of the tranny
I have also mounted the shock absorbers with 650w front and 900w rear, and I have made some progress with the paint and bodywork issue
and up to here all the work of the sunday
Mole-NLD (28 jan 2025 10:08)
FREEDOM83
Bericht door FREEDOM83 » 02 jan 2025 08:52
Today work , small cover for some chasis holes , 1€ and some work
FREEDOM83
Bericht door FREEDOM83 » 04 jan 2025 21:54
In the end I only mounted the bearing supports, the third aluminum member left a little slack and did not rotate as smoothly
To prevent the steering links from moving a little and thus prevent them from hitting the axle housing and getting stuck, some O rings in the balls of the links and problems solved
With all this, finally finished, now we have to try, I would also like to reduce the battle a little but I will try another time
Mud monkey (12 jan 2025 22:16) • Cesco (17 feb 2025 22:51)
FREEDOM83
Bericht door FREEDOM83 » 13 jan 2025 08:47
Released, for the moment I do not have more photos or videos, I was very entertained enjoying it
Mud monkey (21 jan 2025 12:04) • Cesco (17 feb 2025 22:52)
FREEDOM83
Bericht door FREEDOM83 » 22 jan 2025 13:00
That aliexpress rims looks awesome
FREEDOM83
Bericht door FREEDOM83 » 23 jan 2025 08:44
Cesco (10 feb 2025 14:58)
FREEDOM83
Bericht door FREEDOM83 » 27 jan 2025 10:24
I CHANGED the center cover , dont like so much KMC cover , i think this looks better
FREEDOM83
Bericht door FREEDOM83 » 17 feb 2025 10:38
Some photos from Saturday and a friend's invention hahaha
Cesco (17 feb 2025 22:52) • Mole-NLD (20 feb 2025 21:41)
FREEDOM83
Bericht door FREEDOM83 » 31 mar 2025 17:21
