Integy News Topic
Integy News Topic
Bericht door daniel » 30 sep 2017 18:27
In dit topic kan je de laatste nieuwtjes over Integy kwijt. Nieuwe modellen, bodies, banden, accessoires en wat zo meer geleverd wordt.
Officiele website Integy: https://www.integy.com/
Integy Boat trailer
Tow your 1/10 scale RC boats to the lake in scale style with our new Machined Alloy Dual Axle Boat Trailer Kit. Made from alloy, the trailer is designed to transport most 1/10-scale RC boats with a 500-600mm length. Fully functioning leaf spring suspension and realistic 1.9" wheels and tires give the trailer a realistic appearance; the trailer also features a working front retractable stand, metal fenders, quick-release front hitch attachment, and a "tool box" battery enclosure up front with a toggle switch to power the included side marker and brake lamp LEDs. The machined Alloy Dual Boat Trailer kit is available in black or gunmetal Minor assembly is required (installing the fenders and wheels/tires).
Overall Trailer Length: 670mm
Overall Trailer Width: 190mm
Overall Trailer Height: 160mm
Wheel diameter: 45mm
Tire diameter: 75mm
Compatible with most 19"-25" (500-600mm) scale RC boats
NOTE: Instructions for installation are not included; if you do not know how to install the part, please ask your local dealer for assistance. All products require some prep out of the package - some components are assembled for packaging purposes only, so we strongly recommend that you check all metal-to-metal fasteners for tightness, check fitment and adjust if needed, and use liquid threadlock where applicable. Failure to do so is not a warranty-related incident.
Extra hardware, shims, or spacers may be required for some installations. Some parts may require permanent modification to the vehicle for fitment, and may eliminate certain OEM features. Items that are different from `the OEM part (such as our snow & sand conversions, piggyback shocks, EXT suspension, or extended wheel hubs) may require modification to the vehicle for proper clearance. Some Integy-branded items may be only compatible with the vehicle's OEM parts but not with another Integy-branded item due to design limitations. For multiple-fitment items, some parts may not be used based on application.
Item# C27640BLACK Barcode: 91789028781
Integy aluminium axles voor Axial RR10 Bomber
Bericht door daniel » 30 sep 2017 18:33
Upgrade your Axial 1/10 RR10 Bomber 4WD with our new Billet Machined Complete Axle Assemblies. Each axle assembly features aluminum alloy construction, steel hex hardware, alloy suspension mounts, metal internal diff gear and output shafts, ball bearings, and HD drive shafts. The axle assemblies are sold individually; the front axle (#C27112) is available in black, gunmetal, hard-finish, or silver. The rear axle (#C27113) is also available in black, gunmetal, hard-finish, or silver.
Item# C27112SILVER Barcode: 91789027553
CROSS REFERENCE LIST - COMPATIBLE WITH THE FOLLOWING RC CARS AND PARTS
Brand Axial | Part Number AX90048 Brand Axial | Part Number AX90053 Brand Axial | Part Number AX31317 Brand Axial | Part Number AX31316 Brand Axial | Part Number AX80062 Brand Axial | Part Number AX80073 Brand Axial | Part Number AX80072 Brand Axial | Part Number AX30249
Integy Diff cover Axial scx10 II
Bericht door daniel » 30 sep 2017 18:39
Add more flash or that final touch to your custom Axial 1/10-scale SCX10 II by installing our new Billet Machined Alloy Differential Cover. This alloy cover features an aftermarket-looking design with Integy logo, a simulated 'diff lube' port, and perimeter bolt pattern for realism. This piece simply replaces the stock Axial SCX10 II diff cover, and is available in black, gunmetal, 'hard finish', red, or silver.
Item# C27141RED Barcode: 91789027656
Brand Axial | Part Number AX90046 Brand Axial | Part Number AX31384
Re: Integy Boat trailer
Bericht door Mud monkey » 30 sep 2017 21:28
Mooi scale en ziet er goed verzorgd uit
Gegeven waarderingen: 326 keren
Ontvangen waarderingen: 294 keren
Bericht door Patrick » 30 sep 2017 21:35
Wow dat is echt een mooi ding zeg.
Bericht door Wouterb » 01 okt 2017 13:38
Voor ruim €200 mag dat ook wel.
Er zitten wel leuke onderdeeltjes op die voor een zelfbouw trailer van pas kunnen komen....
Re: Integy News Topic
Bericht door Cesco » 21 feb 2019 13:59
Hoewel Traxxas er zelf mee uitkomt heeft Integy ze al geïntroduceerd. Sneeuw of zand? Wielen eraf en rupsbanden erop!
En zoals het Integy vaker doet in een heleboel kleuren, beschikbaar zijn zwart, blauw, rood, groen, grijs, zilver. Al moet gezegd worden dat het meer een kleur accent is.
Even de bijbehorende tekst vertaald:
Voor degenen die graag onbeperkt willen rijden, is onze nieuwe T3 Snowmobile & Sandmobile Conversion nu beschikbaar voor uw 1/10 Traxxas TRX-4 Rock Crawler! De T3-versies hebben een herontworpen lichtmetalen middennaaf, een versterkt voorgevormd hoofdframe en een nieuw loopvlakpatroon voor meer tractie. Deze kunnen op de voor- of achteras van uw TRX-4 worden geïnstalleerd. Verkocht per paar, de T3 Snowmobile & Sandmobile Conversion bevat specifieke installatiehardware en is verkrijgbaar in zeven kleuren.
T3 Snowmobile & Sandmobile Conversion for Traxxas TRX-4
Prijzen rond 150 dollar, dus reken daar nog iets bij op voor euro prijzen.
